Not too sure how well it will work, none of the ignition companies will tell you if it works or not because they said they havent tested it.
The way i look at it is the stator is powering the lights, the flywheel is powering the spark, so it doesnt seem like it will matter.
And any have any problems with burning holes in the top of the pistons with one? Just with the DYNA FS, not because they ran a 200W stator...
Edited by Banshee_Guy
there are 2 sets of windings on the stator, one for the lights and one for the ignition. the magnets in the flywheel rotating around the coils is what produces the voltage.
200watt stator is the rating for the lighting winding, fairly certain.
run them both have no problems
even run the luminator lights which are bad ass with the 200 w kicker pushin it
