sheefreak Posted April 20, 2006 Report Posted April 20, 2006 My bike has been apart since last year and can't remember if the little sleeves that go on the inside long studs on left cylinder go on the right side also. I can only find two, but sold my cyls and may have been stuck in there. When I look at a Microfiche it only shows them on the left cylinder, but cylinder has too much play w/o them. Quote
dajogejr Posted April 20, 2006 Report Posted April 20, 2006 They both go on the back studs (towards the rear of the motor) on the two inner, longer studs. What I did is clean mine up a bit...place them on a stud and used an open end wrench and a few taps with a hammer to settle 'em in place. Quote
sheefreak Posted April 20, 2006 Author Report Posted April 20, 2006 Ok, so there are only two altogether. I couldn't understand why the four inside holes are wide enough for the sleeves though? I am assuming if I go home and put them on the two longer inside studs, the jugs will lose their side to side slop. Quote
dajogejr Posted April 20, 2006 Report Posted April 20, 2006 Now that I think of it...I think there are 4. Each of the four inside studs... Sorry...my mind's been fried from trying to figure out my own dilemna..... Quote
sheefreak Posted April 20, 2006 Author Report Posted April 20, 2006 Thanks for your help daj. I did a little research and found out there are 4 indeed. Quote
