Exactly...  You managed to put into two sentences what took me a paragraph...I've always been a bit long winded...:)
:cheers:
503452[/snapback]
So your saying If im at 40:1 I cant do like 45:1 to make it a bit more lean? I should rejet my entire carbs?
503490[/snapback]
The answer is in many previous posts. 45:1 is a leaner fuel/oil mixture but a RICHER air/fuel ratio. If you did decide to lean your air/fuel ratio by adjusting your mix, you could go to 32:1 to LEAN your air fuel mixture. But I'd probably just re jet the carbs.
