dj_diablo54 Posted April 14, 2006 Report Posted April 14, 2006 Ok So i finally got the suspension done on the bike now I need some more speed. What are some engine mods that will increase some horse power I currently have T5 pippes everything else is stock. but what does everyone recomend on getting first cause it is going to be a slow proccess of buy stuff cause of the new house and shit. thanks Quote
Hilarious Posted April 14, 2006 Report Posted April 14, 2006 Portjob, cool head, better carburetors, stroker crank, adjustable timing plate, aftermarket reeds and cages, 15 or more teeth on the front sproket. Quote
banshee332 Posted April 14, 2006 Report Posted April 14, 2006 call jim from passion racing, tell him what your looking for and he will give you some options. Quote
lowriderb Posted April 15, 2006 Report Posted April 15, 2006 for a slow process build up get things you can use right away.. like a timing plate, head milled and rechambered, air filters, reeds/cages ect.. then once youve got the basic things that you will keep through out the different stages (pipes and such as listed) then you can start picking out your options to go into the motor.. if your going to stay with a stock stroke, port work or different cylinders (depending on the budget your working with), get the crank trued and welded for reliability. if your going to a stroker of any sort make a plan on which size your wanting to begin with then built that motor.. its very hard to build a strong 350 then switch to go to a stroker or something without having to rebuy parts you only needed for the smaler motor.. Quote
