mjr3 Posted April 14, 2006 Report Posted April 14, 2006 my brothers banshee dont know what jets or main hes running has basic sock motor but the bike will not run at all with the carb sliders(throttle valves)facing the right way we switch them were the cut out faces away from the air box toward the front ive read here that cutout should face the airbox carbs were taken apart n cleaned reeds were looked at compression is good bike runs good but when moving the slides the right way it wont run or idle any ideas thanks Quote
suzuki0702 Posted April 14, 2006 Report Posted April 14, 2006 my brothers banshee dont know what jets or main hes running has basic sock motor but the bike will not run at all with the carb sliders(throttle valves)facing the right way we switch them were the cut out faces away from the air box toward the front ive read here that cutout should face the airbox carbs were taken apart n cleaned reeds were looked at compression is good bike runs good but when moving the slides the right way it wont run or idle any ideas thanks 501862[/snapback] ahh ...i had this same problem....did plug chops for a week and didnt know htey had to be in that way...u need to rejet it...rejet the pilot and the adjust the clip on the needle...try kicking it with the choke out...if thats the case and it starts when the choke is out with the slides in correct u are way lean on the pilot circuit..dont mess with the main as htat is just for high on the throttle ...keep us posted...later Quote
