Helping a fellow brother out here on this one.He replaced the floats and needles cleaned them inside and out and it still drips when he rides.Sometimes the bowls run completely dry.
I'm thinking float height issue or something just isnt seating.It's riding season again and I want to get his banshee rolling again and problem free.
Any suggestions..fire away!
I'd say he needs to re-clean the passage way for the fuel from the intake spout, (Compressed air does wonders) make sure the rubber tip of the needle isn't damaged, make sure the needle can move freely within the hole (yeah...that sounds bad...) and then check for correct float height.
21mm if I remember correctly, needle seated position, measuring from the base of the gasket surface to the top of the float (Flat spot when turned upsidedown)
Good luck...I still think it's dirt or sumthin....:)
