sandslinger Posted April 13, 2006 Report Posted April 13, 2006 i came across a used pvl ignition and installed it on a 600cc superior sleeve banshee motor. it starts and runs but i was wondering if anybody knows how to check the timing. the rotor/flywheel that slides on the crank does not have a woodruff key like the normal flywheel. being used, the pvl rotor had a rust spot where the woodruff key was on the old crank so i lined the rust spot up with the woodruff key slot on my crank to get it close. so now how can i check the timing? the stator does have the three mounting holes that are slotted so i can adjust the timing, i just am uncertain how to check it. Quote
