yamahakid1 Posted April 6, 2006 Report Posted April 6, 2006 ok rebuilt the whole engine, got a problem, first the kickstarter kicks from halfway down and then it feels like it has compression, but it used to kick from all the way to the top to the bottom, but mine goes u kick and you dont feel anything till your about halfway down then it kicks like its supposed too, is something wrong here? also to kick the beast over u have to take the filter off and plug the hole for the intake with a towel and after like 5 or 6 kicks it fires, what the heck is that all about, but once you did that u can turn it off and then back on and ti kicks first kick. also both carbs completely cleaned out , but the choke side carb spills gas out and the right side doesnt. what does that mean? any help is much appreciated. One more thing we think there could be a possible air leak on the choke puller because it doesnt stay out anymore u have to pull it and hold it for it to work? should i just buy a whole new choke thing its only 40 dollars. Quote
giantragingmidget Posted April 7, 2006 Report Posted April 7, 2006 FIRST OFF IF THE CHOKE DOESN'T STAY OUT ON ITS OWN YOU SHOULD REPLACE IT. DID YOU HAVE THE CASE SPLIT? IF SO DID THE KICKSTART SPRING GET PLACED IN THE PROPER POSITION DURING REASSEMBLY? Quote
