brilei5 Posted April 2, 2006 Report Posted April 2, 2006 OK Here is whats up. I got it wet crossing a creek yesterday. all the conectors in the rear by the CDI got wet. It would start and idle but give it gas and it would just cut out and bog but not die. I dryed all the conectors out and then it ran fine for a few hours. then at the end of the day it happened at wide open in 6th gear, it felt for a minute like I burned it down, But I stoped and played around with the conentors from stator to the harness, in particular the yellow wire. I wiggle it and it comes back to life. I ride for a few minutes then starts doing it again. So this morning I replace that connector with just a jumper to see if the connector was the problem. It still sputters and bogs. So I swap ouy the DYNA CDI and put the stocker back in take it for a quick spin and pretty much the same problem only with the DYNA give it gas and it falls right on its face with the stock CDI it sputters hard but not as abrupt as with the DYNA.So now I am wondering the STATOR could have gotten wet. could it be toast? BTW the yellow wire connector was just a coincidece I think. I could use some help. If anyone could tell me how to trouble shoot the stator that would be cool. I do have a Digital volt ohm meter. any help would be appreciated. Quote
