ok... so my shee was running fine, then I decided to clean the air filter... well I cleaned it and put it back on... then today I tried to start it for the first time in a month or so and it was only firing one piston... so we messed aroubd with the idles and still couldnt get that piston to fire... we ran a compressions check and got about 115 on each side...the plugs were sparking but now they dont look like they are... And now it wont start on either piston... grrr ... what should I do... any ideas???
:shrugani::shrugani::shrugani::shrugani:
Edited by bucketofsoupyum
unplug your TORS box under your left fender if you haven't already. If its still running shitty, than repost an update.
do you have a k&n, and if so did you use the k&n filter cleaner kit. If you did and did not let the filter dry before you put it back on it can suck all that crap into your carbs and motor.
Double check your spark. Sometimes when you let the bike sit for awhile the connections can corrode enough to cause electrical problems. If you don't have spark try unplugging everything and plugging it back in 1 at a time. If you do have spark, try cleaning the carbs.
sound like fouled plugs to me ..... what kind of oil are you running and is it possible it could have separated from the fuel and you got a over heavy oil mix and fouled plug out? just a thought :shrugani:
