I have a 87 banshee. Starts fine when cold. After I run for awhile and engine is warmed up, it will not start again until it cools down. It does not even have to get to operating temp. Engine runs great when running. I was told it might be stator and got a new one from Ricky Stator. No luck, same problem. The CDI box is a couple years old. So my question is... do you think it is the CDI box or what? Anyone else had this problem?
it's probably jetting....I had a bike that did the same thing....the trick is; turn your choke to half choke (first click up) then give it quarter throttle and kick start it.....mine started everytime...(might need to go up on pilots if your using stock carbs)...hope this helps
