Hmmm.... question...does or will those cylinders work on a 4mm crank???.... i got my bottom end built but havn't got around to pickin anything up for the top end :(
483736[/snapback]
the cylinders n head n domes will work you will have to buy differnt pistons, the pin height on the pistons change for the extra storke or you can get a spacer plate i suggest the differnt pistons, my buddy has the same setup as your tryin to do.any other questions give me a call
