just dont have the time
It has about an hour on it in the last year.
Here are the specs:
1986 Frame with J-arms
Razr Front (not sure on size) and rear(22x11-9)
ITP Race Wheels front and rear
Also has Rear Geicko Paddles on ITP rims (not race rims)
Motion pro Clutch and Brake Cables
Moose Easy Pull Clutch System
Swing arm extended 2 to 3 inches
All Black Yamaha Factory Plastic with Billet Radiator Cover (Fenders no shaved
Lone star Axcalibar Axle 2 to 4+
Armadillo Bumper
White brothers rear skid plate
White Brother Nerf Bars
Russell Stainless Brakes lines
Braking Stainless Steel Racing Rotors
Braking Semi Metallic Pads
Renthal Gold oring Chain
Renthal Rear Sprocket(42 I believe)
Renthal Front (I believe)12 on the bike? But has another size for it also
Pro Design Shocks on the front with reservoirs
Pivot Works Bearings on all joints on Frame
Tiny Tach Meter
Tether Switch
4 Chrome Lazar lights
2002 Engine (Block was brand new when the engine was built. All engine piece brand new when built. About 3 hours on the bike total over a 3 year period
Pro circuit exhaust (I believe platinum)
Boyeson Rad Valves with power reeds
Wiseco Pistons and bearings
Cometic Gasket kit
Wiseco Hot Rod Crankshaft
DG 34 PJ Carb Kit(Twist throttle, Air boxed removed, K and N filters with extenders)
Pro design Cool Heads with 22 Domes (also has some 19s? or 17s? that have never been installed.
Power-Flow Dirt Valve
Barnett Performance Clutch kit(discs and springs)
Moose Clutch Basket
Hinson Pressure Plate
DynoFS Digital ignition
NGK Plug wires
Pro design Adjustable Stator Plate
Moose High Output Stator(265W)
A picture is located at http://www.atvshodeo.com/jpg/Banshee.htm
BIke has a different bumper then what is in the picture. Friend ran it in to a parked vehicle and broke the original. Have a box of extra bolts, cables, ahndle bars and cables. Location SEK Kansas. Great bike... I just dont have time or desire to ride.
Feel free to email me with questions
[email protected]
Just to clear everything up.
The Frame is the only thing that is 1987. Evertyhing else on the bike was bought brand new in 2002 and was ordered for an 02 bIke. Just about everything( not rear shock, Plastic, bolts,wireing harness steering stem,seat) is aftermarket.
