Well I got my CPIs put on,,I did have Fattys,,and it seems like my Fattys hit a little harder,,and it seems like I have to kinda feather the throttle to get it to really get going,,Ive got 33PWK carbs, porting,v force3s , cool head with 19cc domes,and Im running 165 mains, 52 pilot,and needle is in the stock position that the carbs came with,,,,would just changing the pipes cause me to have to rejet,,,the plugs look good with a full throttle run,,just a little sluggish now
What kind of port job did you get?
You may need to call up whomever did your port job for suggestions on jetting.
He ought to be able to help you out. If I'm not mistaken the CPI's will move a lot
more air than the fatties so you may be lean. :shrugani:
How is the fittment on your CPI's, BTW.
Yeap, he is right.. You might want to up the size of your main. What size pilot are you running? those CPI should have you hauling ass right now, unless you have a port job that doesnt agree with them :confused:
480384[/snapback]
find out what needle you have in your carbs.
your mains sound fat to me
im at 145 in ks
wesw are you running 33s also,,I bought my pipes from 23champ on the HQ and he was running35,s and he said he had his needle on the richest position but htat was with a cub also,,,FAST did my porting,,but he is soo busy,,I wanted to see if anyone here had suggestions first,,thanks
Hilarious,,the pipes fit OK,,,it could be better,,I was kinda suprised at that
480585[/snapback]
Don't feel bad about the quality of fit on the CPI's, because I had to send a set of silencers back for replacement. The right side silencer was pointing down, and the left side silencer was pointing up. There was over an inch of difference, and it looked like crap. CPI needs to get some kind of quality control in place, because their quality of fit, usually sucks. :flush:
