jury Posted February 23, 2006 Report Posted February 23, 2006 (edited) do these carriers use the same barings and spacer as stock ones?? thanks CARRIER PICTURE Edited February 23, 2006 by jury Quote
bigboybanshee Posted February 23, 2006 Report Posted February 23, 2006 If I recall correctly, yes they do. I had one before I went with my round style carrier. Quote
woodro77 Posted February 23, 2006 Report Posted February 23, 2006 i dont think they do, i just put one in my raptor and it had a tapered bearing ,and you have to fill the hole carrier with grease. the stock has more of a sealed bearing(i think). the rad carrier came with crush washer that goes inbetween the carrier and the lock nut,because if you tighten the axel down like you do with the stock carrier you will burn out the bearings. there has to be a little play in the axel. you still use all of your stock hardware (rotor , sprocket, locknut, Quote
jury Posted February 24, 2006 Author Report Posted February 24, 2006 alright thanks, when i took the old bearings out they just fell out, i thought they had to be hammered, the bearing were tapered looking, oh well i guess ill put it up for sale. Quote
