jmurrayR6 Posted February 22, 2006 Report Posted February 22, 2006 Ok Im haveing tons of problems My left clinder is not firing and im not the only one. But I may have a solution. I bought this bike with the tors elminator kit install. I have never installed one. I ended up doing a complete rebuilt and plugging in the little black box and throttle switch. Im thinking this tors is the problem mabey there is somthing that isnt plugg in or is plugged in the sould not be. or wires cliped. Can anyone give a step by step on tors so I can run over my system and check everything. Im seeing that everyone that is haveing this problem like me just did a new rebuild and has tors. web address write up anything will help thx guys. Quote
BRIAN BANSHEE Posted February 23, 2006 Report Posted February 23, 2006 theres a search feature on this site that works wonders....... IF YOU USE IT!!!! Quote
ssanddemon Posted February 24, 2006 Report Posted February 24, 2006 Brian is right, this one has been covered again and again. In a nutshell, If you have the eliminator caps and throttle stops in place, unplug all the TORS crap and either throw it out or leave on with the wires hanging. It is then totally out of the loop and affecting nothing. If the guys with cylinder miss are having TORS problems, it's not from lack of this suggestion. I guarantee it gets mentioned every time as one of the first possible sources. You can do a search on 'TORS Meat'. Meat wrote up a really good step-by-step on everything banshee electrical a couple of years ago, should come up. Quote
thegroup Posted February 24, 2006 Report Posted February 24, 2006 "To All Newcomers and Rookies.............." go here before u go any further Quote
