The nicad ones from a hobby store are supposed to last longer anyway. I was just reading it on the MSD site, and they say to get one from a hobby store for extended ride time.
Just order the inline charger, that goes between the stator and voltage regulator. It will charge the battery as long as the RPM's are 3500+, plus at 3500+ RPM''s the ignition will run off of the stator, and not the battery. The charger is only about $30-$35, and it plugs right in.
475278[/snapback]
Does msd sell the charger you mentioned? What would I ask for?
Yes, MSD does have the inline charging circuit. I believe that's what they call it. I got my whole setup, from someplace in Texas, but I can't remember the name of the place. I found a site on the net, that has the part number and installation info. You may have to copy and paste it, but here it is; msdpowersports.com/pdf/frm26214_4214.pdf
Should tell you everything you need to know. One thing I forgot to mention was that I have a 275 watt stator in my Banshee, and it doesn't take long to charge the battery. I do keep the charger I got from Radio Shack in my truck, when I go riding, just in case. If I'm in a hurry and the battery is dead, which has only happened twice in 3-4 years, I just plug it in for 10-15 minutes, and take off, but with that small of a charge in the battery, you don't want it to idle very long at all.
Edited by fastbanshee8
