bansheeman1974 Posted February 13, 2006 Report Posted February 13, 2006 (edited) Hello everybody i am redoing a yamaha blaster top end i have done this before but i am kinda stumped i took the top end apart and looked on top of the piston and it has 50 on it does that mean it is 50 over or what i looked at rmatv and thay have kits for 20,40,60 over but nothing that is 50 over need help thanks.also it does not need to be board out just honed thanks. Edited February 13, 2006 by bansheeman1974 Quote
watkins Posted February 13, 2006 Report Posted February 13, 2006 Guys correct me if im wrong but: 50 means .50 MM so that would be .020 inches or 20 over. Quote
Ducman Posted February 13, 2006 Report Posted February 13, 2006 67.25mm is .050" over for a blaster piston. Vito's sells .050" over pistons in the superstock design. Measure the piston with a set of dial calipers to get the exact diameter, then you'll know what ya got. I wouldn't order a piston unless you know for sure what size, avoid the hastle of having to return parts. Quote
bansheeman1974 Posted February 14, 2006 Author Report Posted February 14, 2006 well thanks for the help guys but i am getting to diffrent things here is it 50 over or 20 over ?? Quote
Lethaface Posted February 14, 2006 Report Posted February 14, 2006 Blasters pistons are available from wiseco in std,10,20,30,40,50,60,70,and 80..I'm not sure about your number, but wanted to let you know that .50 over is out there..Ducman's advice will get you straightend out though Quote
watkins Posted February 14, 2006 Report Posted February 14, 2006 Like I said I was just guessing at the 50.. so take ducmans advise and measure that piston. Quote
bansheeman1974 Posted February 14, 2006 Author Report Posted February 14, 2006 thanks watkins for the help Quote
antmortem Posted February 14, 2006 Report Posted February 14, 2006 (edited) If it is a wiseo piston the number on top is 50mm. There should be some other numbers on top which you can match to the wiseco part numbers. A .20 over piston would be 66.5mm if you measure it with a caliper. Edited February 14, 2006 by antmortem Quote
