I disconnected the plugs that lead to both carbs and the triangle shaped plug by the small black box above the left cylinder. Is it necessary to disconnect the plugs for the parking brake and throttle? From what i can tell, when the black box is disconnected, there is no power to the other wires. I am not sure how the TORS actually operates.
If you disconnected the black box then you are all set. I would suggest getting the TORS  elimination kit so you can get those bulk carb tops off of there.
472621[/snapback]
Yeah, they are such a pain in the arse when it comes to messing with the carbs.
Jeff
