Here are the parts I am selling and I finally took some pics of them,
1. 4mil longrod (115mm) crank trued and welded.
2. Polished cylinders full drag ported by K&T performance
3. Coolhead domes that are built (by K&T) for the 4mil so you don't have to run a spacer plate.
$1150 obo. If you are close to Cheyenne, WY or you want to ship me your motor I will even put it in for you.
This setup with 35mm carbs made over 70hp at over 6000ft elevation. It has 175psi in both sides. This is a great setup just bolt on and go fast.
This motor won the naturally aspirated class at the King Of The Dunes race in Colorado last year. With a stock frame and a 190lb rider...
