cOoLDeviL Posted January 18, 2006 Report Share Posted January 18, 2006 i know that the reed spacer is waste of money on dual carbs and no power gains in no wear . but the single carb have more low end power with less power on top so can i fix this problem by adding reed spacer between the carb boot and the reeds to add more length to the track to help the top end revs ? Quote Link to comment Share on other sites More sharing options...
Wallrat Posted January 18, 2006 Report Share Posted January 18, 2006 If you're using a trinity intake then I'd say its worth trying. I've always thought that trinity made their 2:1 too short and overly complex. Its probably port tuned to about 150 rpms! I'm running a graydon style manifold that I made myself. I think its a better design but since Graydon went out of business the only place to get em is ebay. Quote Link to comment Share on other sites More sharing options...
kenr74 Posted January 18, 2006 Report Share Posted January 18, 2006 Sounds interesting. I have the 35pwk with the Trinity manifold and a pair of 1/2" reed spacers on the shelf. Never thought of combining them but it looks like it should all fit. Not sure about performance though. Quote Link to comment Share on other sites More sharing options...
cOoLDeviL Posted January 19, 2006 Author Report Share Posted January 19, 2006 so if i add the reed spacer between the carb boot and the reed will i still have the same low end power with much better top end . or i will lose some of the low end power to gain the top end ? Quote Link to comment Share on other sites More sharing options...
Wallrat Posted January 19, 2006 Report Share Posted January 19, 2006 Dunno...try it and see what happens. Quote Link to comment Share on other sites More sharing options...
canrider22 Posted January 19, 2006 Report Share Posted January 19, 2006 I have the single 35 from trinity and i put the spacers before the reed's and it realy flatend my powerband out. It used to kick in to hard and when i put the spacers in it was a huge improvment. now i have alot more low end and can cruse in second gear following a slow 4 stroke, and power through the gear without having to dump the clutch or down shift. Someone told me if you put the spacers on the carb side of the reed you will gain ontop, but probably loose on the bottom. I havent tried it yet because about a week after i put the spacers in i had a piston skirt failure. and it is still on the bench. Good luck and please post the results after you have tried them. Quote Link to comment Share on other sites More sharing options...
