Well nitromethane will turn a good motor to junk real fast!!!!
But if you are going to try it, start with about 7% and go up 5 sizes on your jets.
I am asumming you are running alcohol, because nitromethane does not mix with gas. There for you will most likely be drilling your jets out.If your not running a fuel pump, then you will need to get one.
Hope you don't have a nice set of chrome pipe's. Because nitro burns so slow that it will blue your pipe's the first time you start it up.
Unless you have money to waste, then I would stay away from it.... :bolt:
I played w/alky, but I've heard the same thing that enFORCER just said. Expect a lot of bad things to happen. The klotz nitro additive smells nice, but doesn't pack much punch. Klotz makes cozox which, if you mix the 1 gallon of cozox (sounded out as ko-zok) w/4 gallons of premium or race gas, you will have 5 gallons of oxogenated fuel which DOES make more hp (jet up a little for it). Ultra 94 by VP racing fuels is oxygenated also. I know those will give more HP, and I know alky will give more HP, but I can't say how much of a difference there is. Alky probably has more potential because of all it's cooling, etc. The real Nitro is wicked and makes the power, but at a price while learning. banghead
