Let me know if you would like to Trade your Quad for my buggy.
96" Wheelebase frame Aluminum frontend 5 Spoke Spindle Wheels With 3-rib tires CNC Hydrolic Pedals CNC Gas Pedal NEAL Billet Turning Brake FiberGlass Seats Black covers 4" Chrome Headlights 300,000 Candle Power Stainless Steel top Aluminum Flooring Aluminum gas Tank Boxed in trailing arms 2 Piece Porsche Disc Brakes 16.50 Sand Tires Unlimited Paddle tires on 18" Steel wheels 3-rib Bus tranny 2276 Engine 82mm DPR Crank 94mm Pistons and Cylinders FK-8 cam 1.4" Ratio Rockers Chromoly Pushrods Straight Cut Cam Gears 1.5 court Deep Oil Sump Hi-Volume Oil Pump Scat Aluminum PowerPully Scat 5.6" H-Beam Rods SUPERFLOW Heads 44mm x 38mm Valves Aluminum Engine Tins Dual 45mm Dellorto Carbs With Hex bar Linkage One Wire Alt. 1 5/8" Tri-Mill Header with U-Bend Ceramic Coated 009 Distributor with Igniter Lightened Flywheel 4-Puck Clutch 2100 Pound Pressure Plate
Trade or sell outright $6500.00
Thanks, Justin
Ill trade u a 1990 LT500R. New ground up restoration. A ll new bearings and seals nothing old was reused. Black and purple with flame graphics has paddles and dirt tires. Motor was done by trinity racing. All Chrome cases and cylinder. Let me know i do have pics. Give me ur email and i will send the pics. Thanks Cory
