About 2276
  • Birthday 05/20/1978
Contact Methods
  • Website URL
    http://
  • ICQ
    Winfield, Kansas
    1997 Alba Banshee - Yellow and Red T-5 Pipes K&N Filter - No Lid
2276's Achievements
  1. For Sale: Equalizer Hitch 1200lb - 12000lb limit Hitch, Ball, Torsion Bars, Mounting Straps, Bolts, Pins Used for 5 Trips to the dunes, 300 miles each trip. Sold Trailer I don't need hitch anymore. $475.00 Thanks, Justin
  2. Give me your E-mail address and I will send you some pics. Do you have any pics of your quad? Thanks, Justin
  3. Where are you located? later.
  4. Let me know if you would like to Trade your Quad for my buggy. 96" Wheelebase frame Aluminum frontend 5 Spoke Spindle Wheels With 3-rib tires CNC Hydrolic Pedals CNC Gas Pedal NEAL Billet Turning Brake FiberGlass Seats Black covers 4" Chrome Headlights 300,000 Candle Power Stainless Steel top Aluminum Flooring Aluminum gas Tank Boxed in trailing arms 2 Piece Porsche Disc Brakes 16.50 Sand Tires Unlimited Paddle tires on 18" Steel wheels 3-rib Bus tranny 2276 Engine 82mm DPR Crank 94mm Pistons and Cylinders FK-8 cam 1.4" Ratio Rockers Chromoly Pushrods Straight Cut Cam Gears 1.5 court Deep Oil Sump Hi-Volume Oil Pump Scat Aluminum PowerPully Scat 5.6" H-Beam Rods SUPERFLOW Heads 44mm x 38mm Valves Aluminum Engine Tins Dual 45mm Dellorto Carbs With Hex bar Linkage One Wire Alt. 1 5/8" Tri-Mill Header with U-Bend Ceramic Coated 009 Distributor with Igniter Lightened Flywheel 4-Puck Clutch 2100 Pound Pressure Plate Trade or sell outright $6500.00 Thanks, Justin
  5. REDUCED! $$6800.00 Moving Need to sell! ASAP!
  6. Reduced! Email me for Pictures!
  7. Reduced to $6800.00 With Equlizer Hitch $6500.00 WithOut Equlizer Hitch Let me know!
  8. $80.00 I pay shipping Email for pics
  9. 96" Wheelebase frame Aluminum frontend 5 Spoke Spindle Wheels With 3-rib tires CNC Hydrolic Pedals CNC Gas Pedal NEAL Billet Turning Brake FiberGlass Seats Black covers 4" Chrome Headlights 300,000 Candle Power Stainless Steel top Aluminum Flooring Aluminum gas Tank Boxed in trailing arms 2 Piece Porsche Disc Brakes 16.50 Sand Tires Unlimited Paddle tires on 18" Steel wheels 3-rib Bus tranny 2276 Engine 82mm DPR Crank 94mm Pistons and Cylinders FK-8 cam 1.4" Ratio Rockers Chromoly Pushrods Straight Cut Cam Gears 1.5 court Deep Oil Sump Hi-Volume Oil Pump Scat Aluminum PowerPully Scat 5.6" H-Beam Rods SUPERFLOW Heads 44mm x 38mm Valves Aluminum Engine Tins Dual 45mm Dellorto Carbs With Hex bar Linkage One Wire Alt. 1 5/8" Tri-Mill Header with U-Bend Ceramic Coated 009 Distributor with Igniter Lightened Flywheel 4-Puck Clutch 2100 Pound Pressure Plate Email for Pictures $7200.00 OBO! Thanks, Justin
  10. This trailer will hold 2 sandrails or 6 to 8 quads Pulls great with a 1/2 ton Pickup even @70 MPH
  11. Brand New Shipped for $55.00 Thanks, justin
  12. Used Condition Came with a Quad I got. External Res. Seals Don't Leak Come with Red Shock Wears Let me know. $80.00 I pay shipping in the lower 48 States. Thanks, Justin
  13. 2001 Pace Shadow 26`enclosed trailer With ALL the Polished Stainless steel trim on the outside just like a (SHADOW GT) Two cabinets inside, AirConditioner and Heater. (4) 4` Floresant Lights on the celing. (5) 110Volt Outlets. D-Rings in the floor. Ramp Door With Spring Assist in the back. GoodYear Trailer Tires have 2000 miles on them. Also Comes with Equilizer hitch $6,800.00 OBO Email me for pictures. Thanks 620-221-2268 Ext 144 620-222-1422
  14. Price Reduced!!! $6900.00 Thanks, Justin
  15. Sent ya a picture of the outside, Working on one for the inside. Thanks.
