I need stock carbs, clutch cover bolts, and an O ring chain, and possibly a stock carrier and air filter setup. Clamp ons or full air box. I need these parts asap.
I would be willing to trade an SRP dual row billet bearing carrier for some or all of these parts. Bearings are PERFECT, only defect is that the bottom mount has been modified because the bolt was stock in there when I purchased it used, so I had to cut the bottom and modify it. It will still work fine with a banshee as long as you dont jump alot. It kept coming lose when I jumped, but normal riding was fine. Has a grease zerk drilled for easy greasing.
