i had the same problem...
burn all your fuel off, make shure your case is empty, stand your banshee up on end. then buy some J.B Weld, there is two tubes, mix the two together, or at least the ammount you plan on using. then before you apply it, grab an old shop towell and pour a lil bit of rubbing alcohol on it and wipe and clean the area where the drain plug is. also go buy a drain plug from somewhere make shure you buy the one that has a drain plug iside it. so its like a plug that has a plug within it. screw the plug in all the way tight then j.b. weld it on there. and youll still have a drain plug which is inside the new plug, :cheers:
Edited by MonoxideChild420
