Banshee Roost Posted December 10, 2005 Report Posted December 10, 2005 I have installed 320 Mains and left the rest alone . Now just off idle it hesitates and seems like it wants more fuel! What should I do to correct this. My bike seems to flow pretty good maybe even 27.5 pilots maybe? Mods in sig no porting. About 1100 ft elevation. Quote
Justintoxicated Posted December 10, 2005 Report Posted December 10, 2005 (edited) I have Edited December 10, 2005 by Justintoxicated Quote
Banshee Roost Posted December 10, 2005 Author Report Posted December 10, 2005 Yes K&N with snorkle removed and holes in the airbox lid. I will try to raise the needle!Just dont want to do this to many more times . Is the needle under the main jet? Quote
Hilarious Posted December 10, 2005 Report Posted December 10, 2005 Have you tried adjusting your air screws? When you screw em in, it richens up your ldle mixture. If you have em screwed in to about 1 turn to closed, you may need bigger pilot jets. You gotta take the carb tops off to get to the needles. Quote
Banchetta Posted December 11, 2005 Report Posted December 11, 2005 Yes K&N with snorkle removed and holes in the airbox lid. I will try to raise the needle!Just dont want to do this to many more times . Is the needle under the main jet? 447183[/snapback] Definately raise the needle. This will eliminate a lot of that hesitation before the powerband. You'll notice the 4th clip w/ aftermarket reeds and the 5th clip w/ stock reeds would be the best setting.. Quote
