pics?? do they go in thru the inside of the tire??
443915[/snapback]
There's these STUDS
Or these ICE SCREWS these are in various lengths if you scroll in the part number.
Also dEcon I've seen a guy run chans on a 2wd scrambler and they worked very well, I sure wouldn't trust them all you need is something to come loose and it'll cut your shee right into pieces.
Edited by PUSH THE THROTTLE
444454[/snapback]
Exactly, the only time I run the studded tires in at the radar run I go to every year. I don't think I'd like those fukkers comin apart on me at 70+ mph! :wacko:
I run woodys 1.2 steel traction eliminatorsthl_30elimTM_1_colch.jpg 72 per tire. Nothing special other that use that smallest drill you can which is a 7mm track drill. Find a good pattern that will balance at speed. I put a layer of carpet between the studs and the tube, and have not had a problem. Magic racing will have tubes for any size tire in stock.
444454[/snapback]
I see your point. I will be doing some snow riding myself, might try the sheet metal screws
