Shearer pipes o-ring
John19
you have to make a spacer to push the shearers away from the bike a bit
1/4 thick metal with a hole thru it will work
what i did was push the shearers up against the head. put the springs on and them mock the top mounts up
if you just put them on the pipes will rub on the frame
i can get some pic of how mine are if you want
