John19 Posted November 25, 2005 Report Posted November 25, 2005 I just isntalled my pipes and the exaust is leaking around the header where it connects to the cylinders. I feel the exaush pushing itself out. I have all the springs on there and used the o-ring out of my old rockets and its leaking. Any ideas? Quote
wesw Posted November 25, 2005 Report Posted November 25, 2005 you have to make a spacer to push the shearers away from the bike a bit 1/4 thick metal with a hole thru it will work what i did was push the shearers up against the head. put the springs on and them mock the top mounts up if you just put them on the pipes will rub on the frame i can get some pic of how mine are if you want Quote
John19 Posted November 25, 2005 Author Report Posted November 25, 2005 yes please because that doesnt make sense to me. Any help is appreciated! Quote
John19 Posted November 27, 2005 Author Report Posted November 27, 2005 Pics? Still wanting to fix this problem iam having.. Quote
reded Posted November 28, 2005 Report Posted November 28, 2005 Call Jeff at FAST and get the good O-rings. Mine leaks also but someone told me there is a better set of rings available that stop the leak. Quote
