I just rebuilt the carbs on my 95 and it is blowing a ton of fuel/oil out the exhaust.
I also have uneven amounts of smoke comming out of the pipes. One side
blows good and the other doesnt get going til around 1/2 to 3/4 throttle. I
just got this quad so I dont know alot about it. It has FMF pipes and silencers.
K&N pod air filters and aftermarket reeds. I am running 290 jets and 2nd down
on a 5 position needle. What ratio fuel/oil is everyone running?
try re syncing your carbs to the best you can.
i run maxima 927 at 40:1 ratio
you might try your jetting at 290 mains with the needle on the 4th clip and see how it runs.
you might have to adjust your mains on the temp and elevation
Make sure that your slides are in the right way - im speaking from experience!! banghead
They can be put in the wrong carb and the cutout is facing the motor and not airfilter.
this will the symptoms you are talking about. :jesterlaugh:
Mine ran like shit, wouldnt hit the band....wouldnt rev just pissed oil and gas out the exhaust.
Check em!! :clap:
