MATTNEY Posted November 20, 2005 Report Posted November 20, 2005 I just rebuilt the carbs on my 95 and it is blowing a ton of fuel/oil out the exhaust. I also have uneven amounts of smoke comming out of the pipes. One side blows good and the other doesnt get going til around 1/2 to 3/4 throttle. I just got this quad so I dont know alot about it. It has FMF pipes and silencers. K&N pod air filters and aftermarket reeds. I am running 290 jets and 2nd down on a 5 position needle. What ratio fuel/oil is everyone running? Quote
wesw Posted November 20, 2005 Report Posted November 20, 2005 try re syncing your carbs to the best you can. i run maxima 927 at 40:1 ratio you might try your jetting at 290 mains with the needle on the 4th clip and see how it runs. you might have to adjust your mains on the temp and elevation Quote
MATTNEY Posted November 20, 2005 Author Report Posted November 20, 2005 Could you give me some guidlines for synchronization of the carbs? I tried using the window on the carb but there is no mark on the slide. Quote
Hilarious Posted November 20, 2005 Report Posted November 20, 2005 (edited) Click HERE Make sure your choke tube is connected between your carbs too. Edited November 20, 2005 by Hilarious Quote
landw0lf Posted November 23, 2005 Report Posted November 23, 2005 Make sure that your slides are in the right way - im speaking from experience!! They can be put in the wrong carb and the cutout is facing the motor and not airfilter. this will the symptoms you are talking about. Mine ran like shit, wouldnt hit the band....wouldnt rev just pissed oil and gas out the exhaust. Check em!! Quote
