Dr. Overkill Posted November 13, 2005 Report Posted November 13, 2005 Gang, I picked up an '02 shee for my wife ( ) Only problem is that she has a very difficult time reaching the clutch lever due to her tiny hands. She also has trouble with the thumb throttle, even though I put a Thumb Assist on it (something she's used on previous quads and likes a lot--she tried my bike without the Thumb Assist and it was worse for her). She doesn't even bother trying to use the front brake. So, is there anything that I can do to make the clutch easier for her? I could heat the lever and try to bend it in a bit, but that would limit the total throw and might not disengage the clutch completely. I've seen so-called adjustable perches, but I don't know what exactly is adjustable about them. Another alternative might be some way to make the clutch easier to pull in, but still the biggest problem is just reaching the lever with her short fingers. Any suggestions for the clutch lever and thumb throttle (twist is not an option)? thanks! _dennis Quote
brock_fuzzy_69 Posted November 13, 2005 Report Posted November 13, 2005 a hydraulic clutch or look at the suzuki motorcycles they have adjustable clutcha nd brake levers its a 4 position knob so you can set how far from the bar the end of the lever is Quote
