is that for stock or will that go for bolt ons also
432330[/snapback]
BR8ES come out of the box gaped at .030 which is fine for just about any typical stock to heavily moded ported banshee. Some very highly modded she's, like a drag motor might gap a little smaller.
432377[/snapback]
Please, please, please... always check plugs when you pull them out of the box. I know they are supposed to be gapped about average out of the box, but I'll wager a lot that if you pull 10 plugs out of the box you'll get different gaps. For the 1/2 second it takes to check it, why not? Like ssanddemon said .028"-.032". Significantly higher compression will sometimes need a little less gap, so that the spark can still jump the gap, but with basic bolt-ons you should be fine in the stock range.
