wooten Posted November 2, 2005 Report Posted November 2, 2005 (edited) put a new headlight switch on and still no lights cannot figure out what it is i can hook direct power to the lights and they work they are driving me crazy please help!!!!!!!!!!! Edited November 2, 2005 by wooten Quote
pimpeinkc Posted November 2, 2005 Report Posted November 2, 2005 are you getting power from the rectifier? sounds like there must be a wire out some where in the line Quote
Justintoxicated Posted November 2, 2005 Report Posted November 2, 2005 Banshees don't have a retifier, just a regulator. Have you traced the yellow and black wire from the stator and checked the connection to the regulator? Quote
wooten Posted November 2, 2005 Author Report Posted November 2, 2005 where exactly is the regulator on it Quote
3ban5shee0 Posted November 13, 2005 Report Posted November 13, 2005 why do banshee lights suck so much ass ive had all kinds of problems wiith mine check the black and yellow wires going to the stator or even the plugs for the lights they get all messedup to at least mine did Quote
Wallrat Posted November 13, 2005 Report Posted November 13, 2005 Voltage regulator is a little 2" square bastard screwed in under the rear of the seat, next to the larger, black CDI. If you look under the grab bar you'll see it on the right side. Quote
wooten Posted November 14, 2005 Author Report Posted November 14, 2005 i will check it out and hopefully the wires may have came apart lets hope that what it is Quote
