twin 350 Posted October 30, 2005 Report Posted October 30, 2005 hey guys i need to replace my water pump seal. i have bought the seal but what i need to know now is how to do it? has anyone done it before? is there any diagrams or anythin showing how to do this? any help is much appriciated thankyou Quote
bkabina Posted October 30, 2005 Report Posted October 30, 2005 Take off the water pump plate on the outside of the cover.Take the clip and washer,gear and little pin off the back side.Slide the water pump out.Use a socket to drive out the old seal.Be carefull you don't scar the case where the seal goes.Make sure there are no burrs.Lube the new one with some wd-40 or something and drive it in.Make sure you put the seal in rite, it should be marked.oil side/water side.Becarefull putting in the new seal. Quote
bkabina Posted October 30, 2005 Report Posted October 30, 2005 Here is a link from meats web-site.http://thebansheezone.tripod.com/id54.htm It is full of knowladge. The bearing will come out when you drive out the seal. Quote
twin 350 Posted October 31, 2005 Author Report Posted October 31, 2005 thanks guys well im assuming its the water pump seal as i have coolent in my tranny and the oil is grey Quote
PassionRE Posted October 31, 2005 Report Posted October 31, 2005 Once old seal is removed, if you will spray the hole with carb spray or contact cleaner, and also spray the seal as well, you can push the seal in all the way with just your fingers without risking damage to the seal with a driver.....Jim Quote
