This is my first post, so please forgive.
96 370 long rod, mild porting, 18 domes ( 175 lb compresson),
5 deg. adv,fmf fattys,twin 34 keihin, twin k&ns, fuel is 50/50
and I want to set up for sea level and I love to drag.
stock keihins are jetted with 48 ceg needles, clip in middle, 152 mains, and 55 pilot jets.
I want to get the most out of the carbs for the mods i have.
should i get the dynojet kits for 80.00 (choke, choke )or just replace the crappy needles?
I appreciate you taking the time to help.
jerky
with my pj 34s i had the best luck with DEK needles.
my jetting from the dyno on my stroker was 68 pilot, 5th clip dek, 140 mains.
i lowered the pilot to a 60 cause it would load up if not a full throttle.
probably need to go up one size on the mains, will do later.
im at 900 ft elevation. my guess you should be able to run 145 -150 mains for sea level.
by the way the ceg needles made mine run like ass.
i would call sudco.com and order
55 -62 pilots, dek needles, and 140 -155 mains then its test and tune or find a dyno with a sniffer.
thanks for the info.
cant wait to try it out.
pilots might be a little rich but would take care of the off idle bog i have.
it disappears if i turn air screw in all the way.
I have a trip this weekend to an area with several dry lake beds.
great place for plug chop.javascript:emoticon(':bolt:')
smilie
