KoStOnE Posted October 4, 2005 Report Posted October 4, 2005 A rear yfz shock is alot better of a ride then a rear banshee shock ryte? Does anyone know where and around how much i can pick one up if they make a big difference from a stock rear banshee shock. Thanks, Andrew. Quote
Blue Duece Posted October 4, 2005 Report Posted October 4, 2005 rebuild your stocker.........better than a stock 450 shock....or spring for an Elka Quote
KoStOnE Posted October 4, 2005 Author Report Posted October 4, 2005 Since Im new to banshees and shit I wanna learn about them so what do you mean by rebuild your stocker. You mean jsut rebuild the stocks hock and it would be better then a 450 shock. Please aexplain. Thanks alot bro Andrew Quote
Blue Duece Posted October 4, 2005 Report Posted October 4, 2005 Since Im new to banshees and shit I wanna learn about them so what do you mean by rebuild your stocker. You mean jsut rebuild the stocks hock and it would be better then a 450 shock. Please aexplain. Thanks alot bro Andrew 422577[/snapback] You could have Elka rebuild your rear stock hock?.....the front stock hocks belong in the trash can, replace those, and yes a rebuilt stock rear hock is better than a stock rear hock from a 225 ZFY......... Quote
racer Posted October 4, 2005 Report Posted October 4, 2005 plus it wont fit, ot not w/o some "Miller-persuasion" anyway. Quote
KoStOnE Posted October 4, 2005 Author Report Posted October 4, 2005 Alrite thanks alot. So elka could rebuild my rear shock and around how much would that cost and what would they do just replace the old parts with new parts? Quote
racer Posted October 4, 2005 Report Posted October 4, 2005 ya. but instead of having what the factory considers good for all around it will be sprung and valved for your weight and riding style. Quote
Justintoxicated Posted October 4, 2005 Report Posted October 4, 2005 They change the internals, Spring and Valving. The stock shock is decent when setup right. I'd either get the Elka Aftermarket or have TCS revalve the rear. I hear TCS has much better valving than elka. Quote
Blue Duece Posted October 5, 2005 Report Posted October 5, 2005 how ever you go rebuild the rear and replace the fronts Quote
KoStOnE Posted October 5, 2005 Author Report Posted October 5, 2005 Around how much would this cost? Quote
Justintoxicated Posted October 5, 2005 Report Posted October 5, 2005 shoudl be less than 300 I think from TCS but I don't remember for sure. Quote
KoStOnE Posted October 5, 2005 Author Report Posted October 5, 2005 Alrite and how long would rebuilding your rear shock last forever? Quote
Justintoxicated Posted October 5, 2005 Report Posted October 5, 2005 (edited) as long as any other shock probably, although the elka may last longer (???) but it's also 3x as much money...Rear shock housing is similar to aftermarket rear shocks on other quads...the internals are what suffer... It makes a pretty huge difference having your rear re-done...I was suprised.. if you planning to get an extended swinger do it at the same time so you only need to valve it once. I feel it will likely last longer than stock, since they are using better internals. Edited October 5, 2005 by Justintoxicated Quote
