hey bro, I noticed you have the trailtech computer, I just got one and was starting to install it , I got a few questions, did youuse the xtra magnet or use the bolt in the rotor screw?? doesit line up with a hole in the mudguard, or do you have to drill anew one?? which side did you mount it on?how far apart is the magnet and the cable to get correct readings?? Doesnt seem like there is very much space, thanks bra
I TOOK PICS BUT I DONT THINK YOULL NEED THEM ( LET ME KNOW IF U DO ) ... this is how i did my install , i took off the break gaurd circle thing junk . ( i hated the way they made the bike look ) and then i simply mounted the bracket to ware the two screws go for the break gaurd . it basically bolts right on . NOW as for the magnet , i replaced a screw on the disc break with the one supplied in the kit ( magnetic one DUH ) mine is slightly off alinement not anything too serious maybe a few cm outa alinement but it still reads . you might have to give the moutning bracket a little love tap ( nothing too hard ) . also i mounted it on the left side ( if ure sitting on the bike ) if you still run into problem let me know and ill postt the pics , sorry i couldnt respond any sooner i was sleepin and had along friday night lol =-) :cheers:
thansk bra, I've been tinkering with this and mounted it on the lh side too, problem right now is I can't get the fukin rotar screw off, I have a 03 so its not that old, but the bioch is seized good, Ive been soalking it constantly in locktite(just kiddin) anti seize shit(cant rem what is called) and tapping it and heating it with a mini torch and no movey yet. Im gonna get a big torch and a socket with the 6mm hex on it tomarrow and try it again. Any pix would be greatly loved. later time to go chill with mary jane, been a long day............
yeah buddy i used a actual tork rench with a allen head , ( i mean impact rench ) like nascar uses .......
ima take my weels off tomarrow and rotate them and then ill get u some real nice pics so u can see how off mine is , Cheerr's and if mary's with you , shes with me too , HENCE the CHRONIC green banshee =-) :rolleyes:
