I dont know exactly where to put this so im just gonna put it where people are gonna see it most...
im getting really pissed....spent a couple of days working on my banshee....
got the top end done....starts right up and ride it around for like 30 minutes...
i parked it in the garage...and it starts leaking out of the case overflow.......somone already told me it might be some crank bearing seals or sum shit i dont know can someone tell me what is going on?
If the seal or gasket between your water pipe or water pump is letting antifreeze by, it could start to fill up your case and oil may come out the overflow, where the water may sit on the bottom. I'd drain the oil out of the case and see if there isn't anitfreeze in it. It may only be getting into the oil after it warms up. After you shut it off, the coolant is still under pressure, possibly letting some by the o-ring or gasket. Also, I've seen somebody put waaaaaayyy too much oil in a blaster once, and the thing would barely rev, and it would piss oil out the overflow big time. This probably isn't the case in your situation, unless you had a young helper who may have put too much in by accident. :o
