2276 Posted September 13, 2005 Report Posted September 13, 2005 96" Wheelebase frame Aluminum frontend 5 Spoke Spindle Wheels With 3-rib tires CNC Hydrolic Pedals CNC Gas Pedal NEAL Billet Turning Brake FiberGlass Seats Black covers 4" Chrome Headlights 300,000 Candle Power Stainless Steel top Aluminum Flooring Aluminum gas Tank Boxed in trailing arms 2 Piece Porsche Disc Brakes 16.50 Sand Tires Unlimited Paddle tires on 18" Steel wheels 3-rib Bus tranny 2276 Engine 82mm DPR Crank 94mm Pistons and Cylinders FK-8 cam 1.4" Ratio Rockers Chromoly Pushrods Straight Cut Cam Gears 1.5 court Deep Oil Sump Hi-Volume Oil Pump Scat Aluminum PowerPully Scat 5.6" H-Beam Rods SUPERFLOW Heads 44mm x 38mm Valves Aluminum Engine Tins Dual 45mm Dellorto Carbs With Hex bar Linkage One Wire Alt. 1 5/8" Tri-Mill Header with U-Bend Ceramic Coated 009 Distributor with Igniter Lightened Flywheel 4-Puck Clutch 2100 Pound Pressure Plate Email for Pictures $7200.00 OBO! Thanks, Justin Quote
2276 Posted September 19, 2005 Author Report Posted September 19, 2005 REDUCED! $$6800.00 Moving Need to sell! ASAP! Quote
