01 B4C Posted August 29, 2005 Report Posted August 29, 2005 I have only owned this Banshee for about one month. It Quote
Holyman Posted August 29, 2005 Report Posted August 29, 2005 Most banshees will spit a little coolant out on hot days especially on the trails. The coolant you saw on the engine may have been a stray drip from the o-flow hose which comes out above the exhaust pipe. Trace the hoses from the o-flow tank and see if the open drain hose could have dripped where you saw the coolant. This is a very common problem. Quote
01 B4C Posted August 30, 2005 Author Report Posted August 30, 2005 Most banshees will spit a little coolant out on hot days especially on the trails. The coolant you saw on the engine may have been a stray drip from the o-flow hose which comes out above the exhaust pipe. Trace the hoses from the o-flow tank and see if the open drain hose could have dripped where you saw the coolant. This is a very common problem. 409530[/snapback] Thanks, I'll check it out. Do you know if any of those new coolants additives would help me? Which ones? jt Quote
Bansh88 Posted August 30, 2005 Report Posted August 30, 2005 Engine I ce is supposed to be awesome. I used to spit coolant all the time. Then i was told to olnly leave the the resevoir bottle at minimum. stopped spitting after that. Now, I don't even have the res bottle and everything is fine. Quote
