installed a motion pro twist throttle and after I did this the throttle will randomly stick wide open when going through water or puddles any help would be great with this problem cause like the twist throttle way better than the thumb thing. thanks all
The banshee is prone to throttle sticking during wet riding. We have had a very long and unresolved debate over what causes it. I would just make sure that your new twist throttle cable is routed properly and there is no sand or other foreign junk inside the throttle body or throttle tube. These could be MAJOR problems.
I have been told it is moister getting into the carb making the slide stick, you could always put some silicon around were the throttle cable goes into the top of the carb. Not sure if it would work but maybe worth a shot
