road racer Posted August 16, 2005 Report Posted August 16, 2005 How much more top end does the hi rev have over the mids ? Do they give up much low end ? What pipes do they compare to power wise ? Quote
road racer Posted August 17, 2005 Author Report Posted August 17, 2005 Someone must have tried a set if hi-revs ? What did you think of them ? I have mids now but am looking for more top end without giving up all the low end they have . Quote
JKJK Posted August 17, 2005 Report Posted August 17, 2005 The revs will give you a bit more rev compared to the mids.You will loose some mid pull but not that much.The power will be smooth+constant with no spikes from bottom to top.In my opinion they don't have nearly as much over rev as t5's.Compared to the t5's you sacrifice upper rpm pull for the smoothness in the power delivery. Quote
