im getting a motor built by a shop here in my hometown. the guy is using a 4 mil hotrod crank w/long rods. wiseco pistons, pro design cool head with 19cc domes using stock carbs with k&n clamp ons. my question to you is can i send you just the cylinders and have you do the port work and the bore and hone or would you need the whole motor. im looking for mainly low and midrange power with out completely killing the top. what would the turn around time be? also if you did this port job what pipes would you recommend. thanks.
yeah you can send just the cylinders to him. or for 200 he will put it together and other stuff. he makes sure its all right and perfect before sending out.
call him up
