I WAS JUST WONDERING IF ANYONE CAN TELL ME HOW TO TEST THE SECONDARY IGNITION COIL ON MY BANSHEE? I THOUGHT I WAS DOING IT RIGHT BY GOING FROM PLUG WIRE TO COIL BUT NOT SURE..
thats what i though t thanks... im reading ofl... but the weird thing is that there is still a spark, it might not be strong enough to start the quad though right?
Also check your plug caps for 5,000 Ohms. ... The spark should be able to jump a gap of 6mm without the plug cap fitted.
Make sure your spark plugs are clean.
Should be good to go. ;)
EDIT: Just realised you said you were "reading off". ... Didn't work out "ofl". :wacko: . .... How far off? ... When the cylinder's in compression, a weak spark is not going to make the gap.
Rare.
