Bansheeboyz2000 Posted July 15, 2005 Report Posted July 15, 2005 (edited) ok it was running fine but then i got a flat tire, so i let it sit for like 2 weeks while i was waiting for the tire, then i got the tire back on, and it makes a knocking sound from the right cylinder, and i have to like rev it soooo high just to get going and it has NO power what so ever...a friend said blown piston, other friends said rings, i thought it was the mixure, so i ran the gas out and mixed it again, same thing, then i got new plugs..same thing.....WHAT IS GOING ON? if anyone has any idea what is wrong or had the same problem, or knows ANYTHING, just let me know, thanks...ryan i have a 2000 banshee email me at [email protected] or IM me on AIM-BansheeBoyz2000 Edited July 15, 2005 by Bansheeboyz2000 Quote
RNBRAD Posted July 15, 2005 Report Posted July 15, 2005 You need to do a compression check, you may be in need of a set of pistons and rings. Possbily a rebore. Get some compression numbers from each cylinder and get back with us. Quote
Bansheeboyz2000 Posted July 15, 2005 Author Report Posted July 15, 2005 where can i get a compression check?? Quote
Rare Scottish Tree Badger Posted July 15, 2005 Report Posted July 15, 2005 where can i get a compression check?? 392803[/snapback] You mean where do you check the compression, or where do you take it to get it checked? 2nd one's easy. ... A dealer or garage. Where/ how to check compression: 1/ Buy or borrow a decent quality compression tester. 2/ Remove your spark plugs. 3/ Thread the screw in adaptor that matches your spark plug threads, (in diameter and length), into one of the plug holes. 4/ Have the bike switched off, or kill switch set at no run. ... Saves damaging cdi. 5/ Switch the fuel off. 6/ Hold the throttle fully open. (Allows air into the cylinder). 7/ Kick the bike over FAST until the reading on the guage stops increasing. 8/ Release the pressure (guage goes back to zero) and do the same for the other side. Job done. ... Perform the above test with the motor COLD. Rare. Quote
Bansheeboyz2000 Posted July 15, 2005 Author Report Posted July 15, 2005 im very new at this, i just started riding like a month ago, ill have my friend do that, thanks alot...ill get back to you guys with whats goin on.. ryan Quote
racer Posted July 15, 2005 Report Posted July 15, 2005 beware of cheap testers, they arent accurate for the most part! Quote
