one21 Posted July 15, 2005 Report Posted July 15, 2005 I'm kinda new with the drag pipes scene and I am thinking about purchasing some cpi drag pipes..My banshee is bone stock so i need to know what else would i have to have done to put these pipes on..what size jetting? Quote
wesw Posted July 15, 2005 Report Posted July 15, 2005 cpi will allow you to run the stock air box. shearers wont so you are good there. you will have to rejet. if you havent yet you need to get a good air filter setup. pods are probably the best, if you dont run thru a shit load of water. stock box is good, with no lid and a pro design foam or kn filter. depends on your elevations on the jetting. usually if your around 1000 ft somewhat i would say stock pilots, 4th needle clip down, so your raising the needle. adn some 280-300 mains. again it depends on elevation and temp wes Quote
one21 Posted July 17, 2005 Author Report Posted July 17, 2005 Out of frame...But they are not big bore Quote
