strokersquid Posted July 9, 2005 Report Posted July 9, 2005 i own several rz 350s and banshee cranks fit and are better. i bought a stock hot rods crank on e bay supposedly only run 4 hrs and welded. the bearings look good but the big end clearance is .030 on one side ( which on a stock rz crank would be at the service limit ) the crank is only welded at the outer pins and not in the inners and the loose side inner pin is not flush with the web, but puuled in slightly. should i return it or is this ok. i spent $275 on it but i thought it was worth it if as advertised Quote
