akpopeye Posted July 6, 2005 Report Posted July 6, 2005 Hye guys, im still trying to get rid of whats left of my rz and banshee stuff after i finished my project...i got a ton extra....i got a really nice rz top end, all bored, with a kit, never installed...and a bunch of other rz and banshee stuff...email me for a parts list..its too long to post here and i doubt many people care too much abou the rz part of it... thanks...cameron. Quote
akpopeye Posted July 6, 2005 Author Report Posted July 6, 2005 [email protected] would work best.... Quote
Holyman Posted July 7, 2005 Report Posted July 7, 2005 Here's my suggestion... Start a list here anyway. If you are going to put it on eBay you'll still have to list the stuff. Besides that, some folks don't know they want something until it's set out in front of them. How much do you want for the RZ top end? Is it ported? What bore is it on? Quote
akpopeye Posted July 7, 2005 Author Report Posted July 7, 2005 Thanks Holyman.......the top end was bored by specII, a rz specific shop, comes with new piston kit with all new hardware, none of this was ever installed since the shop work..heres what i got into it: cylinders: 100 bore: 90 vavles cleaned professionally: 35 Piston kit: 135, it is stamped 1 on top... milled head: 90 Plus at least 50 in shipping Thats 500 into it.......I would like to get 400, not bad for top end thats all done and never installed Here is the list... 1.RZ Top end (new unused piston kit, freshly bored cylinders, professionally cleaned valves, reed cage, wrist pins, wrings) 2. Milled Head 3. Ignition Coil 1 4. Wiring Harness with fuse box 4. Forks 5. Gauges and panel, shows 188645, with the 5 shown in white 6. Banshee Swing arm 7. Silencers and Expansion Chambers 8. Silencers, dinged 9. Body- Tailpeice with chrome piece in original paint 10. Body- Over the tire Peice 11. Body- Side peices 12. Body- Chin, small hairline crack near a bolt mount, still solid as if not there 13. Body- Upper fairing, not original paint, and one bracket broke off, zip ties holding well and solid. 14. Gas tank, 2 little bolts rattling around, probably got in there from traveling with other parts. 15. rz headlight 16. oil tank 17. air filter Clutch basket, showing grooving 18. Stock RZ Carbs 19. 28mm RD Carbs 20. 2 up seat, looks great 21. RD tachometer 22. Complete seal kit 23. side mirror 24. YPVS Controller 25. Cases with hairline crack??? 26. Trued, welded Crank Shaft, from a banshee 27. RZ Tranny gear clusters 28. RZ driver side mirror 29. RZs peedometer 30. RZ Foot Pegs 31. Kick Start Lever, RZ 32. RZ Head Bolts 33. Stainless Steel (new) bolt kit, everything you need to put the cases together and cylinders mounted, for stator cover, clutch cover, insert....ect...everything.....banshee head bolts included too 34. Kick Start gear 1 35. Kick Start gear 2 36. NOS head gasket 37. rz banshee gear drum and star 38. RZ Wheels with New Metzler tires 39. RZ frame with papers 40. Wiring Harness 2 41. RZ Ignition 2 42. Fork mounts 43. RZ All electrical wiring and all mounting hardware 44. RZ Tail light assembly 45. Misc hardware... 46. FZ600 Swing arm WWII Canteen KDS Avitron Monitor 19inch Flat Screen Compaq IJ1200 ink jet printer Quote
Holyman Posted July 7, 2005 Report Posted July 7, 2005 Heck of a deal on that top end. #6 Is the banshee swingarm stock? #19 How much for the RD carbs? RZcolobanshee may need #24 is that the servo or the box? #25 Are the cases really cracked? If so where and how much do you want? Thanks Quote
super88_banshee Posted July 7, 2005 Report Posted July 7, 2005 #5 Guages, does an rz tachometer work on a banshee?? Quote
03LE Posted July 7, 2005 Report Posted July 7, 2005 Is your monitor a lcd like flat monitor or a normal monitor with a flat glass front? Quote
rzcolobanshee Posted July 7, 2005 Report Posted July 7, 2005 If you have a servo motor I'll buy it #5 Guages, does an rz tachometer work on a banshee?? 389686[/snapback] Not without the drive gears (pretty much need the top half of the case) Quote
akpopeye Posted July 7, 2005 Author Report Posted July 7, 2005 rzcolo: the servomotor is yours, I paid over 30 for it, so how bout 30? give me an email to discuss it [email protected] super88: rzcolo is of course right about that, you would have to run rz cases, i have an rd tach that you could mount to your banshee, but you would have to buy rz cases 03LE: the monitor is one with a flat screen, not a flat panel, just a flat viewing surface, it is not very "thin" Chapmanmd: Yes, it is a good deal, but I would like to do it outside of paypal, or I would like the buyer to pay a percentage to cover the cost that paypal charges me.....people on the site can verify my credibility.....i can give some references if honesty is a worry.....basically i want 400 in my pocket for it, not 400 less shipping and paypal fees.... Holyman: the carbs i would like 45?? I paid 55 and never installed them The swingarm is a banshee stocker. Here is the honest story: I sold them, thought all is fine, but the buyer said there is a hariline crack in the bottom case.....so i refunded him and now i have the cases again. Will the hairline affect performance, can it be fixed, I dont know.....where is it? I can't find it yet, but i am sure it is there, the buyer was very good and knew what he was doing, more than me? He is a member also, Chris Yax. I will pm him and see if he can help me find it so i can photo it.....if it can be fixed, Ill take best offer on it....... Quote
akpopeye Posted July 7, 2005 Author Report Posted July 7, 2005 The story after mentioning the stock swingarm was in reference to the cases....sorry, forgot, was too long of a post Quote
03LE Posted July 7, 2005 Report Posted July 7, 2005 okies dokies thanks for the info, I'm lookin for a flat panel one of these days...maybe I'll just suck it up and by a new one Quote
Holyman Posted July 7, 2005 Report Posted July 7, 2005 Can you send me apic of the carbs and the cases??? [email protected] Quote
akpopeye Posted July 7, 2005 Author Report Posted July 7, 2005 o3le, go to tiger direct, IM getting a flat panel lcd for 189, there is one for 169, if you think its too cheap, if it lasts for only two years, that still is a good deal... tigerdirect.com holyman, pics will be on their way Quote
chapmanmd Posted July 7, 2005 Report Posted July 7, 2005 Could you please send pics of the cylinders and stuff to [email protected]? Thanks. Quote
